Beiträge von stojced
Alles anzeigen
In the meantime I have found something.
Firstly, I got a professional solution for €350 which can access all aspects of my PHEV, including the electronic parking brake, via a separate tablet and a corresponding app.
I also bought another OBD2 Bluetooth adapter from Amazon for just under 60€ and use it with the app "Car Scanner ELM OBD2", which is available for Android phones in the Play Store as a free version and as a paid Pro version.
This app can be used to read out all parameters that come via the OBD interface and there are really a lot of them, including the oil temperature.
I can then display the whole thing on my phone in the app on a separate, freely configurable screen, but I still have to get to grips with it because the app is really very comprehensive and the good thing is, it works on all of my motorcycles.
greeting
Mike
Hi Mike,
Can you pls share which OBD2 Bluetooth adapter you procured from Amazon (link would be great).
Tnks,
Stojche
I had the same, and it was not the DPF, since there is different message when this is issue. I left the car for 2 days, and after examination dealer stated that some temperature sensor on the exhaust needs to be replaced. They have cleared the error and I have driven the car for 3 weeks while waiting for part, and error did not re-appear, but anyhow they have replaced the sensor and no problem after that, I have drove additional 7000 km.
Unfortunately, this is not only possible with diesel engines with a plug-in with a parking package, but there is a module for retrofitting then I think it will also work for you, but with an additional remote control
Tnks !
Ich nutze sie immer zum Auto auftauen weil sie 10 Minuten am Stück läuft, sich dann automatisch abschaltet
Und man kann zum Beispiel vorab auf Scheiben einstellen dann geht sie morgens genauso an für diese 10 Minuten wenn ich ihn über die Fernbedienung einschalte
Ich würde es gerne für den gleichen Zweck verwenden, den Innenraum vor dem Betreten abtauen und auch erwärmen. Ich habe Diesel, 7-Gang-DCT mit nahezu vollständiger Ausstattung (in Mazedonien gibt es verschiedene Ausstattungspakete), aber ein Fernstart war bei keinem davon eine Option.
Vielen Dank an alle. Ich reise nach Mazedonien, und dort gibt es kein Gesetz, das den Leerlauf verbietet. Ich habe gelesen, dass es bei einigen Anbietern eine Tastenkombination gibt, die „aus der Ferne“ startet, aber bei Tucson sieht das nicht so aus.
Weiß jemand, ob es eine Reihenfolge zum Fernstarten des Autos gibt, wenn Sie einen 3-Tasten-Smart-Key ohne „Fernstart“-Taste haben?
I just checked, for my 1.6 CRDI 136PS there is the following entry according to the Hyundai website:
Engine damage from water hammer
Valid until: 31.12.2025
Campaign code: 30DC03
Ich habe das selbe. Haben Sie den Händler gefragt, was zu tun ist?
Alles anzeigen
ich hab bisher nur gespannt mitgelesen. Jetzt hab ich aber auch mal ein Problem und hoffe, dass mir jemand helfen kann.
Ich hab die neue Software installiert und seit dem 2 Probleme. Das eine ist, dass ich Blue Link nicht mehr aktivieren kann. Bleibt immer im Status "registriert", aber wenn ich das Navi
nutzen will, werde ich dann aufgefordert Blue Link zu aktivieren. Das klappt aber nicht. Habs auch schon deaktiviert und wieder von Vorn angefangen. Hab sogar schon einen Werksreset vom Navi gemacht.
Alles ohne Erfolg. BAs zweite ist, dass beim Grücken der Spracherkennung jetzt eine Meldung "Software Missmatch" kommt. Der Support von Hyundai konnte mir nicht helfen.
Jetzt frage ich mcih, ob ich mit dem Softwarestand zurück kann. Hat jemand eine ältere Software zum download parat ? Oder sonst einen Tipp ? Viele Grüße und Danke im Voraus.
Hast du schon mal versucht die neue Software zu installieren?
wäre interessant welches Modell /Motor Du hast……
Ich habe Diesel 1.6 100KW, DCT-Getriebe (Shift by Wire). Das Ausstattungsniveau ist Impression, aber da ich aus Nordmazedonien komme, ist es schwer, es mit Ihren Modellen zu vergleichen (im Grunde handelt es sich um ein voll ausgestattetes Modell ohne elektrische Sitze).
